Activity Forums Adobe After Effects lock layer position?
  • lock layer position?
    Posted by Kendall Shaw on January 18, 2015 at 4:54 pm
    I keep discovering that somewhere in the middle of video I have managed to bump the position of a layer, which makes me have to track down where it is and fix it…. Argghhh.
    I have guides locked. I have disabled the arrow keys. But, I sometimes accidentally move a layer with my mouse. Sometimes means rarely. But, it only has to happen once to be a disaster.
    All layers are meant to fit the composition size currently. Obviously, this won’t always be the case. I can use fit to comp, once I find out where I have bumped the video. But, is there a way to lock the position so I can’t accidentally bump it?
    I am aware that I can avoid the problem by not bumping the layers. But, you can compare it to the idea of parachutes in airplanes. You can bring a parachute or learn not to have airplane accidents. But, the later choice is not prudent.
    Kendall Shaw replied 11 years, 7 months ago 2 Members · 2 Replies
  • Walter Soyka
    January 18, 2015 at 5:39 pm
    [Kendall Shaw] “All layers are meant to fit the composition size currently. Obviously, this won’t always be the case. I can use fit to comp, once I find out where I have bumped the video. But, is there a way to lock the position so I can’t accidentally bump it?”
    You can lock the layer.
    You can also use an expression for the position, so that it will override keyframes. For example, if your position is [960,540] and you want to lock that, alt+click the position stopwatch and enter the following expression:
    [960,540]
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Kendall Shaw
    January 20, 2015 at 3:56 am
    Thanks. Locking layers when not changing them seems like a good idea.
