Activity › Forums › Adobe After Effects › Location of layers not the same of null objects with the same position
  • Location of layers not the same of null objects with the same position
    Posted by Shane Shornock on July 21, 2023 at 2:49 pm
    I have set up a floor plane and spread 6 layers across the surface. I then created null objects with the same position at the same location but they are not at the same location. I also copied the positions of each layer to one null object to control a camera but the same thing happens
    Filip Vandueren replied 3 years, 2 months ago 2 Members · 1 Reply
  • Filip Vandueren
    July 22, 2023 at 8:00 am
    Hi Shane,
    The layers are parented to the floor, the Nulls are not.
    The values of the layers position are relative to their parent. So even if they share the same numbers, they are at a different location in space.
