Activity Forums Adobe After Effects location of AFX render templates….
  • location of AFX render templates….
    Posted by Chad Briggs on February 15, 2008 at 9:35 pm
    Does anybody know where the file is that after effects stores the render/output templates? i know you can import/export them, but i’m trying to figure out a way to automate these over the network, where i can just do a batch update, and update everyones templates.
    hope that makes sense.
    thanks
    -Chad
    Chad Briggs replied 18 years, 7 months ago 2 Members · 2 Replies
  • Jan Sherlink
    February 16, 2008 at 1:14 pm
    On PC you can find it in
    C:\Documents and Settings\USERNAME\Application Data\Adobe\After Effects\7.0
    The file is Hidden and is called:
    Adobe After Effects 7.0 Prefs.txt
    Probably looks the same for CS3
    cya,
    Jan
  • Chad Briggs
    February 16, 2008 at 5:30 pm
    Ah! There it is. I knew it existed somewhere. Thanks Jan! much appreciated.
    -chad
