Activity › Forums › Letters to the COW Team › Location change
Location change
Posted by Misha Aranyshev on April 21, 2014 at 10:14 amI tried to change my location in the profile by typing the new one when prompted but it doesn’t stick. Where do I go about it?
Misha Aranyshev replied 11 years, 2 months ago 3 Members · 21 Replies -
Abraham Chaffin
April 21, 2014 at 3:05 pmHello Michael,
Your detected location will change when you IP address changes, because your IP changes frequently, this will happen frequently.
On the other hand, the location which is stated on your public profile (https://my.creativecow.net/Michael-Aranyshev) will not change until you manually change it.
Misha Aranyshev
April 21, 2014 at 6:25 pmHi Abraham,
I’m trying to change my location here: https://my.creativecow.net/manage_location.php. It doesn’t work.
Abraham Chaffin
April 21, 2014 at 6:49 pmHello Michael,
Thank you for reporting your problems with this page. Either the page was out of date, due to a Google map update, or your JavaScript was disabled.
I believe this link is working, and the newest version of the location update system:
https://cow.creativecow.net/manage/location
The old link is now redirecting to the new location. I also added a note in the new page, which will appear if you do not have JavaScript enabled. JavaScript must be enabled for the update to work correctly.
Please let us know if you run into any more difficulties.
Thanks again!
Misha Aranyshev
April 21, 2014 at 7:30 pmI have JavaScript enabled, pop-up block disabled, all 3rd party extensions disabled in Safari. I emptied the caches and quit and relaunched Safari. Still there is just empty space where Google map is supposed to be at the link you provided.
Sorry
Abraham Chaffin
April 21, 2014 at 8:03 pmHmm… that is very strange.
Do you get any note about JavaScript above the empty space?
What version of Safari are you using?
Do you have this issue in Chrome and/or Firefox?Are you able to see this page:
https://cr8v.co/wPLor this page:
https://forums.creativecow.net/docs/forums/readpost/h/map.php?lon=-120.728792&lat=36.1915Hopefully we can get to the bottom of this for you.
Misha Aranyshev
April 22, 2014 at 12:40 amI don’t get any note about JavaScript above the empty space.
My Safari is version 7.0.3 (9537.75.14).
I get the same behaviour in Firefox.I can see both links.
There is some development. When I switch from TimeWarner Cable to T-Mobile the map on the page is loading. I can edit my location there, both the pin on the map and the name in the field above the map.. It just doesn’t show in my profile.
Abraham Chaffin
April 22, 2014 at 2:58 pmIt sounds like there is some issue with your ISP blocking some content there.
I have the same version of Safari, and it works well for me.
Perhaps you could test using Firebug, or Chrome’s development tools to check what specifically is being blocked. I would assume it is something between your ISP and Google, but you’ll need to dig around on your end to find out what it is specifically.This is a good tool for finding what you are looking for:
https://getfirebug.com/wiki/index.php/Net_PanelHope this helps.
Dax Roggio
June 22, 2015 at 12:04 amWere you ever able to change your location? No matter what I do, the location for my Creative Cow profile is stuck on Brooklyn. I’ve tried to set it to Phildelphia many times from different browsers and on different connections. When I click on “Manage Location,” it properly lists Philadelphia and shows Philly marked on the map, but the location on the main page of my profile refuses to update. Also, my job notifications are still coming in for the New York area, instead of Philadelphia.
Misha Aranyshev
June 22, 2015 at 1:34 amPartially. It shows the edited location at the top of the page in the forums, but in my profile page it is still the original one.
