Activity Forums Apple Final Cut Pro Legacy locate corrupt media files?
  • locate corrupt media files?
    Posted by George Mandl on August 31, 2010 at 6:54 pm
    FCP is definitely not where the answer to this problem lives, but I thought this forum would reach like-minded people with similar issues.
    I’m working on a film with a few thousand pieces of media. I’ve got one FCP project that has all the footage organized into bins, and most clips are merged clips consisting of ProRes video, and synced sound. There are no sequences at all. The media lives on an XSAN. This particular project likes to crash – the beach ball pops up and just hangs there. Occasionally it stops, but usually it requires a force quit.
    I have tried:
    – Trashing preferences
    – creating new projects and copying the bins into them
    – unlinking and relinking the media
    I suspect there must be something corrupt, but since there are so many media files, I don’t really know where to begin. I’m wondering if anyone knows of a program that will scan a folder for corrupt data and isolate it.
    I tried Treasured, but this only does one file at a time.
    And if there is a better forum to post this in, please let me know.
    Thanks for reading,
    George
    George Mandl replied 15 years, 12 months ago 5 Members · 11 Replies
  • 11 Replies
  • Shane Ross
    August 31, 2010 at 7:08 pm
    https://www.digitalrebellion.com
    You want the FCS Maintenance Pack. It has a corrupt clip finder. In fact, it has a LOT of great tools for figuring out what is causing problems.
    Shane
  • Michael Sacci
    August 31, 2010 at 7:09 pm
    Take a look at FCS Maintance
    https://www.digitalrebellion.com/fcs_maintenance.htm
    Corrupt Clip Finder
    I don’t have this but use there free software and it is great.
  • George Mandl
    August 31, 2010 at 7:12 pm
    Thanks guys! I’ll give it a try.
  • Shane Ross
    HA! Great minds!
    I do use this and it works.
    Shane
  • George Mandl
    August 31, 2010 at 8:00 pm
    Good news bad news. The good news is that I have ZERO corrupt files.
    The bad news is…. now what?
    Does FCP have a point at which it will say “hey there are way too many files in your project, of course I’m going to crash on you.” ? I have about 10,000 in my main project, but even when broken in half, the halves behave the same way. Maybe I need to go much smaller. If anyone knows the actual number of files FCP can handle, please advise.
    Thanks again!
  • Shane Ross
    August 31, 2010 at 8:02 pm
    10,000? Not too bad. How large is the project? Get Info on the project file and tell us how many MB it is. Anything over 100MB can be problematic.
    Shane
  • George Mandl
    August 31, 2010 at 8:13 pm
    29.4 MB
    It lives on the XSAN, but I’ve also tried keeping a copy on my local drive. Same result either way.
    Oddly, we have larger projects (80MB or so) that are slow to open, but once open seem to work pretty well. The projects have sequences with many many cuts in them.
    My footage project has no sequences. Just bins with clips of merged media.
  • John Pale
    August 31, 2010 at 8:29 pm
    The video is Pro Res…what are the specs on the audio?
  • George Mandl
    August 31, 2010 at 8:52 pm
    Linear PCM, 24 bit little-endian signed integer, 48000 Hz
  • Gary Askham
    September 1, 2010 at 10:39 am
    You say the project is on the XSAN? This is a bit of a no-no. I don’t think it’s the cause of your problems but it could lead to problems further down the line. There is a continuing issue where FCP projects working from XSAN volumes can become corrupt. It’s always a good idea to keep the project local (Desktop or Documents folder). You can set the Autosave Vault to the XSAN but keep the working project local.
    FCP and Avid Technical Support
    Air Post Production
    Shoreditch – London
