Activity › Forums › Apple Final Cut Pro Legacy › Locate clip in browser/bin
Posted by Jean-jacques Briquet on May 11, 2006 at 6:42 pmHi, I am trying to find a way to locatea clip in the browser/bin from the time line or viewer. I looked for this feature but could not find it.
Thanks in advance for any help
JJ
Jean-jacques Briquet replied 20 years, 3 months ago 3 Members · 4 Replies -
Luke David
May 11, 2006 at 6:51 pmfrom the timeline you can hit F to match frame, then you hit shift F to locate in the bin
May 11, 2006 at 10:08 pmThanks a lot Luke. I noticed it doe snot work if the clip is not in the Master Clips bin after using media manger.
JJ
Nick Meyers
May 12, 2006 at 12:38 ama master-affiliate relationship has to exist for this to work,
and it’s not too hard to break that relationship.
it breaks if your clip is in one project, and your timeline in another.
and on larger projects, keeping track of it can just get too hard for FCP, and it just crumbles under the pressure.
twice i’ve gotten a warning telling me that due to some corruption i’ve lost it.luckily my projects are well organised, and i know where to find the clips just by looking for them.
there is an option to use “Create Master Clips” (in the tools menu)
this will create new master clips for you for all the clips that don’t still have the relationship.
they’ll get put into a new “Master Clips from (Sequence name)” bin
if you’ve got any organisation going, you’ll then have to put al those clips into appropriate bins, and ditch the old one.nick
