Activity › Forums › Apple Final Cut Pro Legacy › loading/viewing prob
  • loading/viewing prob
    Posted by Geraint Pari huws on January 23, 2006 at 12:48 pm
    help
    loading off j3o firewire to mac firewire.
    very basic set up, no external interfaces…
    media loads/playsback correctly during and after digitise, however,
    audio plays back intermintently/out of sync/ as if badly rate converted whilst viewing off tape.
    any suggestions?
    thanks in advance
    amheus
    Geraint Pari huws replied 20 years, 8 months ago 2 Members · 2 Replies
  • Kevin Monahan
    January 23, 2006 at 7:44 pm
    Hook up speakers and TV monitor to the deck/camcorder and NOT the Mac.
    Kevin Monahan
    Take My FCP Master’s Seminar!
    fcpworld.com
  • Geraint Pari huws
    January 24, 2006 at 9:34 am
    thanks for the reply…
    I’m aware that I can avoid hearing the problem, but still need to know the cause, audio off the j3 is embedded 16bit 48khz off digibeta, why is the g5/fcp giving me rate converted playback? Is there an issue with the g5 itself, can I choose ” which rate the mac works. G5 spec says it works at 44.1 or 48, can I change this within the mac.I’m worreid if it does this whilst viewing that I may face the smae problem when digitising, I’m fairly confident that all my project setting are set for 48khz audio but I admit I’m an Avid guy and not expert with fcp
    thanks agin
    gph
