Activity › Forums › DaVinci Resolve › Loading memory resets RED settings. Sometimes.
  • Blase Theodore
    February 26, 2011 at 2:16 pm
    I think the RED clip info is saved as part of the grade in the newest versions. Is it possibly just recalling a grade that had no red settings applied to it?
  • Mikhail Puzyrev
    February 26, 2011 at 5:22 pm
    Yes, after experimenting, found that if I use first shot from group of connected shots – everything goes as it should because I ve set clip red settings. But if I save memory from any other chunk but not the first – it resets red settings of the target clip to project state.
