  • Posted by Letitbleed on October 18, 2005 at 7:10 pm
    Hello,
    I’m putting a site together with a little bit of flash and mostly html…The idea was to use html in case someone has a slow connection so they could at least use the site and let the flash movies load in the background. Then it would play eventually but not interupt the use of the rest of the site. Right now I have a lot of frames and the flash frames want to load first which takes a while and the html frames, the menu buttons, backgrounds etc…are all just waiting this whole time until all flash has loaded. Is there anyway to give the html stuff the priority and have the flash load in the background then play when it’s finished? I’ve been trying to figure out loading frames in order but realized that that would also just make the flash frames load last but none of the html text or pictures, in the same frame as the flash, will show up or load in those frames until the flash is done loading.
    Sorry my question is so long and thanks for any help.
    LIB
    Curtis Thompson replied 20 years, 11 months ago 2 Members · 1 Reply
