Activity Forums VEGAS Pro Loading clips with alpha-channels enabled
  • Loading clips with alpha-channels enabled
    Posted by Omer Aydin on August 12, 2010 at 9:40 am
    Hello,
    Is there any quick way for loading clips in timeline with their alpha channels already enabled?
    John Rofrano replied 16 years, 1 month ago 2 Members · 7 Replies
  • 7 Replies
  • John Rofrano
    August 12, 2010 at 7:22 pm
    It depends on the file type. You could load one, turn on the alpha channel and then save that setting for all files of that type. Then when you drop a bunch of files of the same type, all of the alpha channels will be set.
    Like this:
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Omer Aydin
    August 12, 2010 at 11:56 pm
    Thanks for the reply John, unfortunately this solution didn’t work for me.
    I dropped in a pre-keyed .mov file into the timeline and adjusted the properties just like you have posted above and saved the preset.
    I tried adding in the other .mov files and they still had no alpha enabled.
    Besides, it appears the saved preset only works in current project.
    I had to re-adjust all clips when I imported them into another project.
  • John Rofrano
    August 14, 2010 at 2:58 am
    You’re right. I couldn’t get to to work for MOV files either. Maybe this only works for image formats or maybe it’s just a bug in Vegas.
    ~jr
  • Omer Aydin
    August 14, 2010 at 12:48 pm
    If only Vegas allowed adjusting properties of multi-selected clips.
    I think alpha of image files are auto-enabled when loaded.
    I agree that it may be a bug, or maybe it’s just for saving the stream type property.
  • John Rofrano
    August 14, 2010 at 3:57 pm
    You can easily do this with a script plug-in like VASST Ultimate S Pro. Excalibur might also have this capability. If you are editing in Vegas without a script productivity plug-in you are missing out on a lot of powerful functionality.
    I have a script on the Vegas Scripts page of my web site that will set the alpha channel for all selected events.
    Here is the source:
    //* Program: SetAlphaChannel.cs
    //* Author: John Rofrano
    //* Description: This script sets the alpha channel for selected events
    //* Last Updated: July 6, 2010
    //* Copyright: (c) 2010, Sundance Media Group/VASST, All Rights Reserved
    using System;
    using System.Collections;
    using System.Windows.Forms;
    using Sony.Vegas;
    class EntryPoint
    public void FromVegas(Vegas vegas)
    try
    foreach (Track track in vegas.Project.Tracks)
    if (!track.IsVideo()) continue; // only process video tracks
    foreach (TrackEvent trackEvent in track.Events)
    if (trackEvent.Selected && trackEvent.ActiveTake != null)
    VideoStream videoStream = trackEvent.ActiveTake.MediaStream as VideoStream;
    videoStream.AlphaChannel = VideoAlphaType.Straight;
    catch (Exception e)
    MessageBox.Show(e.Message, "Set Alpha Channel Error", MessageBoxButtons.OK, MessageBoxIcon.Error);
    ~jr
  • Omer Aydin
    August 14, 2010 at 5:43 pm
    I downloaded the script and tried it on the .mov clips. You have saved me from editing a lot of alpha property. Thank you John 🙂
  • John Rofrano
    August 14, 2010 at 6:00 pm
    You are very welcome. Glad I could help.
    ~jr
