Activity › Forums › Maxon Cinema 4D › Loaded image for a texture does not show.
  • Loaded image for a texture does not show.
    Posted by Petar Georgiev on June 2, 2017 at 8:31 am
    Hello.
    So I shattered an extruded text with Nitroblast but the inside part doesn’t get affected correctly by the material. In color I have loaded a lava jpg image for texture but it renderes it completely red. It’s not the lava image I have loaded. I made a screenshot so you can see. Thanks in advance for the help.
    Jim Scott replied 9 years, 3 months ago 2 Members · 1 Reply
  • Jim Scott
    June 2, 2017 at 2:50 pm
    I don’t know which version of the plugin you have, but using NitroBlast2 this is how I changed the interior material of a sphere which has had the plugin applied.
    1) Select the texture tag in the Objects menu for the inside material. (It’s the material labelled “Style_Default IN” in the Materials Manager, and for which the tag will show “X-IN_Selection” in the Selection window of the tag’s properties.)
    2) Drag your new material from the Materials Manager into the Material window of the tag’s properties.
    In my example below I added a new material – “redrover” – and dragged that into the tag’s Material properties window.
    Hope this helps.
