Activity › Forums › Apple Final Cut Pro Legacy › Loaded DV NTSC tapes on a DSR-11 with the PAL switch selected
  • Loaded DV NTSC tapes on a DSR-11 with the PAL switch selected
    Posted by Jake Diamond on May 8, 2007 at 3:14 pm
    Please pardon my ignorance, but I have a question. I’m working on a DV NTSC project on Final Cut 5.1.2, and four mini DV NTSC tapes were loaded last night via firewire on a DSR-11 with the PAL switch mistakenly selected. However, when I cut them into the NTSV DV timeline (720×480, 48k), they don’t need to be rendered and they look and sound okay. Does the firewire cable ignore the setting on the deck, or is there something I’m missing and these tapes need to be re-loaded correctly.
    Thank you,
    Jake
    Rennie Klymyk replied 19 years, 4 months ago 4 Members · 4 Replies
  • Jerry Hofmann
    May 8, 2007 at 3:30 pm
    Select one and type cmd+9… see if indeed it’s NTSC. I’ll bet it is though, and if so you are good to edit sans recapture.
    I think the switch on the back only affects RECORDING not playback.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Graeme Nattress
    May 8, 2007 at 3:41 pm
    I think you’re right – might only be for recording. I think the deck “knows” what format the tape is for playback.
    Graeme
    – http://www.nattress.com – Film Effects and Standards Conversion for FCP
  • Jake Diamond
    May 8, 2007 at 3:59 pm
    Thanks guys – good to know – I just checked a few of the clips and they are indeed NTSC. I appreciate your help.
    Jake
  • Rennie Klymyk
    May 8, 2007 at 4:55 pm
    FYI
    the DSR-11 will auto select the format for playback through the DV connector automatically and display the type on the front panel. Check your timecode though because with the pal switch on the back set to pal it records non drop frame T/C. This will over ride the menu settings for the T/C generator.
