Activity Forums Avid Media Composer LOAD FILLER SHORTCUT
  • LOAD FILLER SHORTCUT
    Posted by Ken Wanninger on May 1, 2008 at 8:40 pm
    Hello,
    I’m using Media Composer 2.8 on Mac. Is there a way to make a shortcut or button to Load Filler, and even possibly insert it into the timeline at current position? The reason I ask is that I am used to select/move all tracks forward on Final Cut Pro, it’s very handy, and I’d like to find a way to do something similar on Avid.
    Thanks in advance for your help!
    Ken
    Michael Hancock replied 18 years, 4 months ago 2 Members · 1 Reply
  • Michael Hancock
    May 1, 2008 at 8:42 pm
    It’s possible to map Load Filler to the keyboard.
    Go to your Settings tab, open Keyboard.
    Open the Control Panel (Ctrl+3 on a PC). Check Menu to Button in the control panel.
    Click the button you want to map Load Filler to, then go to the menu command for Load Filler. I think it’s under the Clip menu. It will map that to your keyboard.
    I have mine set to Shift+F, for Filler.
    Michael.
