Activity Forums Adobe After Effects Load different Codec?
  • Load different Codec?
    Posted by Joey on April 20, 2005 at 9:34 pm
    When you go to export the video I have the option of Quicktime or AVI . Is there a way I can get more options ? Can you upload more options somewhere ?
    Steve Roberts replied 21 years, 5 months ago 3 Members · 5 Replies
  • Steve Roberts
    April 20, 2005 at 10:32 pm
    Use composition>make movie. The vast majority of AE renders are done that way, through the render queue. File>export is for special cases.
    For more details, check the help.
    Steve
  • Yoondo
    April 21, 2005 at 5:15 am
    [Steve Roberts] “File>export is for special cases”
    Hi Steve, could you let me know why you would export?
    Thank you.
  • Steve Roberts
    April 21, 2005 at 5:23 am
    Let’s see … anything that can’t be done in the render queue, such as SWF, AVI (on Mac) or DV stream.
    I’ve only ever exported to SWF. I don’t make AVIs anymore (Indeo who?) and when .dv files are needed, I’ve used Cleaner. Maybe I’ll try AE for those sometime.
    Steve
  • Joey
    April 21, 2005 at 1:26 pm
    I found more codecs in under the settings for each one but is there a lossless AVI or equivilent so after I add an effect I can edit it into my movie for DVD quality?
    Thanks Joey
  • Steve Roberts
    April 21, 2005 at 1:53 pm
    Look in the output module and set the compressor to “none”.
    Steve
