Activity › Forums › Video Copilot › load a path from a raster based matte
Posted by Paul Rijkaard on May 27, 2008 at 9:49 pmHi Team
I am trying to articulate the edges of a silhouette of a figure using active light streaks similar to Andrew Kramer’s tutorial on audio to animation
https://www.videocopilot.net/tutorials.html?id=64
I am specifically interested in the line electrically passing around the edge of the figure – the body of which will consist of energy fields – an electric man!!
the source for the silhouette is produced in imagineer systems mocha – from which the full body matte can be exported as shape data, as an alpha channel or as a silhouette matte.
I would like to load the edge data as a live path for the light streaks but can’t figure a way to do this in AFX,
any help would be very gratefully accepted
Paul Richards
Paul Rijkaard replied 18 years, 2 months ago 3 Members · 8 Replies -
Ron Coy
May 28, 2008 at 5:21 pmoh, man… I don’t know of a quick solution. Not with paths anyway. You could just use something that affects alpha edges.
I don’t know of any way to make paths from the alpha of the layer, except for a tedious importing of every frame into Photoshop and converting the alpha to a path, which doesn’t even work that well, or using the path tracing stuff in Illustrator, which also wouldn’t work that well, and would be even more tedious, or just Rotoscoping the whole thing, which, again, is tedious, but probably your best bet, with the best results.
you might try looking for an effect to affect the alpha, like Shine
Paul Rijkaard
May 29, 2008 at 7:10 amThere must be a way to deal with this – there just must be – all of the information other than the calculated vector line is available
just to confirm again – I would like to use the silhouette of a moving figure to trace the figure’s outline and use this outline as a motion path for a light beam effect.
Perhaps I am complicating it somewhere along the line?
I recently bought Shine and Form – but have spent most of my time in Form – can you briefly explain what it can do for alphas??
Ron Coy
May 29, 2008 at 2:33 pmShine doesn’t do anything for alphas, but if you have element in your scene with an alpha channel, obviously, Shine can effect just the edges of the element as opposed to the entire thing, or just the alpha channel itself. It’s a drop down menu within the plugin settings box, I believe it’s Composite and the options are “On Original, Alpha, and Alpha Edges”. There may be another option, but I don’t have it open and in front of me right now.
With Alpha Edges selected, you can adjust the settings to give an edge glow type effect that’s more dynamic than just a standard glow. As far as extracting the path from an alpha, I just don’t think there is a tool for that. Maybe someone should or will make one, but I don’t know of one.
Try going to Toolfarm and looking for something there. They are basically plugin central.
Ron Coy
May 29, 2008 at 4:06 pmok. I found something that might work, but it’s in beta.
Masks to Shapes
http://www.redefinery.com/ae/view.php?item=rd_MasksToShapes
There is also one called Shapes to Masks
http://www.redefinery.com/ae/view.php?item=rd_ShapesToMasks
One of these may be able to get you there. They only work in CS3 though.
Paul Rijkaard
May 29, 2008 at 5:43 pmThanks for this – although there is still the problem of generating a shape/path from a raster file – although it could be conceivable to write an action in photoshop that loads each frame selection and makes a path –
but this leads to a problem of how to bring together many paths into one keyframed/roto path??
perhaps the answer lies back in motor/mocha which can export shape data but not to after effects – only to combustion/flame/shake
does anybody know of a work around with this? I am not familiar with these applications??
Jeff Kosmicki
June 11, 2008 at 8:38 pmSorry for the late response, this may be too late but you can select the layer you want to make a mask for and then go to layer/auto-trace. You can then select to make a static mask from a single frame or animated from a range of frames.
Jeff Kosmicki
http://www.toyraygun.net -
Jeff Kosmicki
June 11, 2008 at 8:39 pmSorry for the late response, this may be too late but you can select the layer you want to make a mask for and then go to layer/auto-trace. You can then select to make a static mask from a single frame or animated from a range of frames.
Jeff Kosmicki
Paul Rijkaard
June 11, 2008 at 9:45 pmThank you so much – it is such an obvious command that has been staring me in the face but it really really has solved my problems. the results are incredible. thank you thank you
paul richards
