Activity Forums Maxon Cinema 4D Lo Res quicker render?
  • Lo Res quicker render?
    Posted by Rick Morton on December 24, 2019 at 7:15 pm
    I’m building a fairly intense animation that takes a LONG Tim to render each frame. Isn’t there a way I can do a “lo res” render to see how the overall animation is looking without waiting for 24 hours to see it? I’m sure I’m just not seeing the obvious somewhere, but can’t even find a tutorial about this.
    Sam Treadway replied 6 years, 8 months ago 2 Members · 1 Reply
  • Sam Treadway
    December 25, 2019 at 2:55 am
    There is the “Make Preview” command which lets you choose from full render or hardware openGL in R21. In Maya this is referred to as a “playblast”.
    In r21 the command is in the Animate menu. In earlier versions it may be located in the Render menu.
    Hardware OpenGL is the quickest but will show just as it does in the viewport so you may want to turn off splines and other distractions and turn on Enhanced OpenGL features before making the preview render.
    Another option is to duplicate your current render settings (bottom left of render settings dialog) and make that duplicate a child of the original and name it preview. Change the render engine on the child to hardware openGL and under the openGL category turn on/off the enhanced features to balance speed and readability. Once you find settings that you like then right-click on the setting name and choose “Save Preset…”
