Activity Forums Maxon Cinema 4D llustrator CS5 Ruller does not work when exporting files for C4D
  • llustrator CS5 Ruller does not work when exporting files for C4D
    Posted by Zak Peric on August 1, 2010 at 7:07 pm
    HI All,
    I am apologizing if this came up, after searching the forum I could not find the workaround for Exporting (set rulers to center horizontally and vertically in CS5 Illustrator for Mac).
    After watching few tutorials I noticed that all people are exporting their text or paths from illustrator CS4 or earlier versions to be in the center of the artwork, this helps with positioning the artwork in c4D in the center. When I export the file and set the rulers in CS5 Illustrator, the rulers defaults to the top left. I am using Illustrator 8 as a version for export.
    Anybody found a solution to fix this problems with CS5 Illustrator please.
    Just learning C4D and loving it.
    Zak Peric replied 16 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
