Activity Forums Canon Cameras Living element inside my XF300 lens
  • Living element inside my XF300 lens
    Posted by Ruy Fajardo on July 6, 2012 at 1:09 am
    Hi dudes im troubled, i found 2 nasty white elements living inside my new XF300 and they walk around the second and the third glass of the lens. i need to kill them until i can send it to guarantee in the usa. I bought the XF in the USA but im not there at this time.
    How much cold or heat can i apply to my camcorder? i want to neutralize them for a couple of weeks until i can reach a service center. What else can i do?
    Sad
    Killabyte
    Joel Servetz replied 14 years, 2 months ago 2 Members · 3 Replies
  • Joel Servetz
    July 6, 2012 at 7:35 pm
    I would not subject the lens to any extremes of cold or heat or attempt to do anything at all, for fear of violating the warranty. Seal it in a ziploc type bag until you can send it out.
    Joel Servetz
    RGB Media Services, LLC
    Sarasota, Fl
    videobyjoel@aol.com
    http://www.rgbmediaservices.com
  • Ruy Fajardo
    July 7, 2012 at 5:36 pm
    Thats sure, but the specs for the camcorder allow to be between 0-40 C degrees so ill play a little with the temp and in a couple of weeks i will send the camcorder for repair.
    Do you have an idea of what could be done to it if under warranty? is it possible that the lens become replaced?
    best
  • Joel Servetz
    July 9, 2012 at 4:50 pm
    It’s unlikely to be replaced, they’ll probably disassemble, clean and re-assemble the lens.
    Joel Servetz
    Sarasota, Fl
    videobyjoel@aol.com
