Activity Forums Apple Final Cut Pro Legacy Livetype to FCP problem
  • Livetype to FCP problem
    Posted by Lawrence Gray on August 14, 2008 at 2:47 pm
    I’ve created a title in Livetype and want to import it into FCP. Unfortunately when I do this all I get is a black screen with one of the type layers appearing.
    I’ve rendered the file. I’ve saved. I’ve imported the Livetype file and can see no reason why I shouldn’t get the file as displayed in livetype.
    If I save the normal render preview movie and import that, then I get the file as it should be… though a lot less quality… at least I think it must be less quality as it comes in as a small image I need to enlarge.
    What’s the trick here?
    Tom Wolsky replied 18 years ago 3 Members · 10 Replies
  • 10 Replies
  • Rafael Amador
    August 14, 2008 at 3:11 pm
    Does the file shows “Strait Alpha” in the FCs Browser?
    Rafael
    http://www.nagavideo.com
  • Lawrence Gray
    August 14, 2008 at 5:51 pm
    Yes it does… Should it?
    Lawrence Gray
  • Rafael Amador
    August 15, 2008 at 2:46 am
    Yes, otherwise no transparency.
    Don’t you have the IN/OUT points in wrong place and are you exporting with “Render Only between IN/OUT points”?
    Rafael
  • Lawrence Gray
    August 15, 2008 at 3:09 am
    The In and Out points seem OK. If I click Render Background when rendering to Movie then i get the clip properly exported.
    However, if I merely save the ipr file and import that into FC I still have the same problem. No background.
    The default setting is a tick in the Render Background box when creating a .mov and no tick in the Render Background box.
    How do I change that?
  • Rafael Amador
    August 15, 2008 at 9:26 am
    Is very strange this behave.
    If you have no background in the time-line, is the same if the “Render Background” is checked or not.
    So if it works with “Render Background”, open your project and in the export window check this option.
    Rafael
  • Lawrence Gray
    August 15, 2008 at 10:18 am
    You don’t get any options when you save a Livetype file. It works when you export the .mov file but not when you simply import the Livetype file, as it is supposed to.
    In another message group someone with a similar problem complains that Livetype has a problem with Intel Macs. I wonder if it has anything to do with that.
    Lawrence Gray
  • Rafael Amador
    August 15, 2008 at 10:41 am
    There I can not help you much. I never work with with LiveType files. I always export a .mov.
    The truth is that I work quite little with LiveType. To be able to export only as Animation is a hug limitation.
    Rafael
  • Tom Wolsky
    August 15, 2008 at 10:59 am
    Being Intel has nothing to with it. What version of LiveType? What version of FCP? Is there anything in the LT project other than LT elements? If not, can you send me the LT Project? Can you put the LT project inside a Motion project?
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Lawrence Gray
    August 15, 2008 at 11:22 am
    Livetype 2.1.3
    FCP 6.04
    I’m just using a Livetype Template.
    Haven’t a clue about Motion. I’ve yet to open it and even look at the manual! I’ve signed up for a course later in the year.
    Send your e-mail and I’ll send you the file.
    Lawrence Gray
  • Tom Wolsky
    August 15, 2008 at 11:30 am
    Click on my face at the op of the forum. There’s a web link on the page to South Coast Productions. The info needs to be updated by there are email links on the pages.
    All the best,
    Tom
