Activity Forums Apple Final Cut Pro Legacy Livetype files missing elements
  • Livetype files missing elements
    Posted by Dave Beaty on January 15, 2009 at 4:13 pm
    Recently I’ve begun having issues with Livetype project files imported into my FCPro 6.0.5 sequences. The graphic elements/objects/textures I’ve used behind the text elements are missing. This is not a “render background” issue and the elements are missing even if they are in the foreground tracks.
    What I found out is that FCPro started interpreting the alpha of these files as straight which removed the backing elements. If I switch it to None, they come back. Just FYI. Not sure if this is a change with Livetype or with FCPro.
    Dave Beaty
    Dreamtime Entertainment
    1625 SE 46th St
    Cape Coral FL 33904
    239-549-4081
    800-446-7575
    dave@dreamtimeentertainment.com
    http://www.dreamtimeentertainment.com
    Dave Beaty replied 17 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
