Activity Forums Apple Final Cut Pro Legacy livetype crawl not smooth
  • livetype crawl not smooth
    Posted by Moztu on June 9, 2005 at 11:42 am
    Hello to all,
    We have done a very simple crawl right to left with a couple of dates using livetype. It looks fine on the computer screen but when you view it on ta tv screen it looks as if the dates where moving with small jumps. Anybody knows about this? how to solve it?
    cheers,
    moztu
    Bret Williams replied 21 years, 2 months ago 3 Members · 3 Replies
  • Moztu
    June 9, 2005 at 12:50 pm
    Ok people, we have found a solution. We were rendering using none field dominance and when we changed to odd field dominance it seems to work! it is strange since we thought that working with DV you need field dominance set at even, that
  • Walter Biscardi
    June 9, 2005 at 1:29 pm
    Generally for NTSC it is lower field first and for PAL it is upper field first. However, I’ve found that in some (not all) Motion projects, they work better with Upper Field first. Weird I know, but if the titles look smooth, they leave it alone. 🙂
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Bret Williams
    June 9, 2005 at 1:58 pm
    If I remember right, the LiveType interface is just labeled wrong.
