Activity › Forums › Apple Final Cut Pro Legacy › Livetype
Livetype
Posted by Justin Edwards on November 26, 2005 at 1:06 pmOk. I got Livetype, and I got the 2 Data Discs with the Live Fonts, effects, and such. How do I get them to work in Livetype? Is there a folder I have to drag them into?
Jerry Hofmann replied 20 years, 10 months ago 4 Members · 6 Replies -
Jerry Hofmann
November 26, 2005 at 2:07 pmPut them in startup disk/Library/application support/Livetype folder.
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Bret Williams
November 26, 2005 at 3:57 pmThey get installed when you install LiveType. Unless you opted not to. I think if I remember right there’s a preference in LiveType to point to the LiveType data files.
I recently moved mine to another drive, and when I opened LT it asked where they were, and I pointed it.
Kevin Monahan
November 26, 2005 at 9:24 pmBret is correct. You reconnect them in the LT prefs dialog.
Kevin Monahan
Take My FCP Master’s Seminar!
fcpworld.com -
Jerry Hofmann
November 27, 2005 at 7:27 pmLook in the LiveType menu.
Jerry
