Activity Forums Broadcasting Livestream – dropped frames in recorded video
  • Livestream – dropped frames in recorded video
    Posted by Marina Cotrim on March 30, 2017 at 8:38 pm
    Hi everyone,
    Where I work, we use Livestream Studio to capture videos from a broadcast camera.
    We’ve been using the same set up in a few months, but recently we are having problems with dropped frames.
    At some point in the video (wich normally has 20-30 minutes), the audio “crackles”, the sync is lost, and we notice that there was a jump in the video.
    Then the video continues ok, the audio is delayed by some frames.
    I looked at the file info with Media Info and here’s what I got:
    General
    Complete name : 03-03.mp4
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom
    File size : 1.46 GiB
    Duration : 25mn 12s
    Overall bit rate mode : Variable
    Overall bit rate : 8 307 Kbps
    Encoded date : UTC 2017-03-06 11:44:41
    Tagged date : UTC 2017-03-18 18:39:15
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 1 frame
    Format settings, GOP : M=1, N=60
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 25mn 12s
    Bit rate mode : Variable
    Bit rate : 7 983 Kbps
    Maximum bit rate : 12.1 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Variable
    Frame rate : 29.970 fps
    Minimum frame rate : 9.990 fps
    Maximum frame rate : 29.970 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.128
    Stream size : 1.41 GiB (96%)
    Language : English
    Tagged date : UTC 2017-03-06 11:44:41
    Audio
    Format : AAC
    Format/Info : Advanced Audio Codec
    Format profile : LC
    Codec ID : 40
    Duration : 25mn 12s
    Bit rate : 320 Kbps
    Channel(s) : 2 channels
    Channel positions : Front: L R
    Sampling rate : 44.1 KHz
    Compression mode : Lossy
    Stream size : 57.7 MiB (4%)
    Language : English
    I noticed the framerate is variable, but i’m sure that the reason for that is the dropped frames. When the problem doesn’t happen, the framerate is constant.
    Also, it’s not an internet issue, because i’m not livestreaming (and even offline sometimes).
    Does anyone has any ideas on how to fix it?
    Thank you!
    Marina Cotrim replied 9 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
