Activity Forums Blackmagic Design livekey not working
  • livekey not working
    Posted by Alexander Falk on May 25, 2008 at 8:30 pm
    hi guys,
    for another time since some years i tried livekey for logo-burnin, but had no luck to bring it to work.
    i followed exactly the descriptions on bmd-homepage (unfortunately no documentation in the tool itself), but the result is always the same.
    my setup:
    power mac g5 dual 2,5 ghz
    mac os x 10.4.11
    decklink hd pro 4:4:4
    decklink driver v 6.6.7
    final cut pro 6.0.3
    workflow:
    1. set both input of videocard to receive sd-pal.
    2. started livekey
    3. set from “off” to “internal key” (didn’t change the standard key-image)
    = results in no video output!
    i played around with the tool, but didn’t find the right setup to work.
    if i use external key, i can see the fill and alpha information, but video input is still missing.
    but the main problem is that it didnt evene work approximately.
    any help?
    4 x Avid Media COmposer Adrenaline 2.7+
    2 x Avid Media Composer Mojo SDI 2.7+
    1 x Avid Symphony Nitris 1.6.3
    1 x Avid DS Nitris 8.1
    1 x Decklink HD Pro PCI-X 4:4:4
    1 x Decklink HD Pro PCI-X 4:2:2
    1 x Decklink SD Pro
    2 x Decklink SD Extreme
    1 x Workgroup Videohub
    4 x HDLink
    Alexander Falk replied 18 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
