Activity Forums Apple Motion LiveFonts disappear after being applied to text
  • LiveFonts disappear after being applied to text
    Posted by Roger Stoneburner on March 10, 2011 at 5:52 pm
    Pulling what little hair I have left out 🙂
    I’ve tried adding several different livefonts to text with the same results, the text disappears completely.
    I’ve even solo’d the text layer and added it then, only to see the text disappear. I’ve scrolled later in timeline with no luck.
    Help…
    Micah Debenedetto replied 15 years, 4 months ago 3 Members · 3 Replies
  • Roger Stoneburner
    March 10, 2011 at 6:33 pm
    is it possible livefonts are not loaded on my comp but the icons still show in Motion?
    anyone?
  • Jimmylee Remillard
    March 11, 2011 at 2:02 pm
    Im pretty sure the problem is the loop setting. When you go into the inspector tab, then text tab, then format.. All the way at the bottom you will see live font settings. Its most likly the loop is not set to a high enough number. Remeber livefonts are video files being played as text.
  • Micah Debenedetto
    April 10, 2011 at 6:14 pm
    thank you.
