Activity › Forums › Apple Final Cut Pro Legacy › Live Type Text and DV PAL problem!
  • Live Type Text and DV PAL problem!
    Posted by Rob Evans on March 14, 2009 at 3:51 pm
    Hi ,
    I’ve been up and down the forum but I can’t find an answer to my problem! I’m using the latest version of FCP and regularly edit using footage captured from my HD XDCAM F335 camera – using Live Type with no problems. But, now I’m editing some family footage taken on a Sony DCR-PC330E PAL mini DV camera and can’t get clear titles on the timeline!
    The titles don’t appear sharp and try as I may, I’m not getting anywhere fast! I’m using Live Type version 2.1.3 and my play-out monitor is a 23″ Apple monitor attached to an MXO box.
    I’ve tried adjusting the settings in LT to mirror the Sequence Settings in FCP but the text isn’t sharp! I’ve saved the project in LT, imported the file into FCP and then rendered – still no improvement!
    I’ve tried messing around with the Field Dominance settings in the title clip, but I’m changing all of the FCP timeline settings in the process.
    Can anyone throw any light on this problem please.
    Regards,
    Rob
    Using a 2 x 2.8 Ghz Quad-Core with 4GB of memory
    Rob Evans replied 17 years, 6 months ago 3 Members · 6 Replies
  • Rafael Amador
    March 14, 2009 at 4:22 pm
    [Rob Evans] “PAL mini DV “
    Change your sequence codec to something better than DV: DV50, 8/10b Unc, ProRess, PhotoJPEG75%.
    Any of those codecs will make your graphics look better.
    rafael
    http://www.nagavideo.com
    (and here some clips for the friends: https://www.vimeo.com/2694745 )
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Rob Evans
    March 14, 2009 at 6:14 pm
    Hi Rafael,
    Thanks for responding. Do you mean changing the codec on the timeline? For example, I double click the title on the timeline and leave the play head on the clip. Then go to Sequence/Settings and change the codec under the General tab? Or have I got it wrong?
    If that is what you mean, I’ve tried it and it didn’t work. Perhaps I’m doing something wrong!
    Rob
  • David Roth weiss
    March 14, 2009 at 6:21 pm
    What he meant to say was, go to Sequence>>Settings and change the compressor to a 4:2:2 codec such as DV50, ProRes, or 8-bit uncompressed, then re-render the timeline.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Rob Evans
    March 15, 2009 at 12:32 pm
    Hi all,
    David, that’s what I thought Rafael meant and the quality didn’t improve. However, when I changed the Field Dominance to ‘None’ the text looked a lot clearer and that was with the Compressor set to DV-PAL!
    I then played my edited footage and it all played well until it hit a still image and then you noticed a problem with the picture. So I reset the Field Dominance settings back to Lower (Even) and of course my titles don’t look crisp and clear!
    Your thoughts?
    Rob
  • Rafael Amador
    March 15, 2009 at 2:16 pm
    Render to a better quality codec in very helpful in post (Graphics, CC, effects rendering), however it can helps nothing with interlacing issues.
    Is very important to know the correct field order of a clip before bringing it to a sequence. Most of all if you have not an interlaced monitor.
    No much fun to discover that was something wrong after printing 25.000 DVDs:-)
    Rafael
  • Rob Evans
    March 16, 2009 at 12:53 am
    It seems a way forward is to place my LiveType text on the timeline and change the Field Dominance to none in the sequence settings. But what can I do with the two freeze frames I have further along the timeline? Because of the change in FD the two stills now jitter!
    Is there a way of getting around that problem?
    Rob
