Activity Forums Apple Final Cut Pro Legacy live type loses Alpha in FCP – help
  • live type loses Alpha in FCP – help
    Posted by Kathy on July 25, 2005 at 1:42 pm
    I’ve just upgraded to Tiger and FCP 5. When I make a title in
    Live Type it’s fine. When I import it into FCP and play it in the browser it has an alpha channel. When I pop it onto the timeline
    the alpha channel goes and it’s black behind. What’s happening?
    Kathy
    Kathy replied 21 years, 1 month ago 5 Members · 9 Replies
  • 9 Replies
  • Walter Biscardi
    July 25, 2005 at 1:59 pm
    What does the Properties of the clip say?
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Kathy
    July 25, 2005 at 2:10 pm
    Type: Clip
    compressor: animation
    Field dominance: Upper
    Alpha Straight
    composite: normal
  • Walter Biscardi
    July 25, 2005 at 2:19 pm
    That all sounds correct and I just checked a clip here with an alpha channel and it has the same settings as that. Not really sure why the alpha would not be working correctly then.
  • Kathy
    July 25, 2005 at 2:23 pm
    Now, Walter, that’s not what I wanted to hear!!
    Kathy
  • Bret Williams
    July 25, 2005 at 3:11 pm
    I think there were some similar post weeks ago. They were about AE renders with alpha. Both are animation codec so it should be the same issue. Something about installing FCP 5 in the correct order. QT, OS, the FCP 5 maybe?
    I’m just getting FCP 5 today so no first had experience yet.
  • Walter Biscardi
    July 25, 2005 at 3:18 pm
    It shouldn’t make a difference but if you’re working in NTSC, your field order needs to be lower field first.
  • Robert Garry
    July 25, 2005 at 6:18 pm
    make sure in LT that you go to the “Project Properties” pane and UNCHECK “Render Background.”
    If you have been using a black (or other color) to give your text more contrast in LT and you had the aforementioned checkbox active you are actually exporting the backplate as well.
    If it is unchecked already make sure you have no unwanted layers above the background bar (It’s the bar that splits the timline horizontally). Anything below that bar will be considered background and only render according to your preferences, if any elements are above the bar they will render out as a total composite.
    Good Luck
  • Ramesh Jai
    July 26, 2005 at 1:06 am
    Ok here it goes…..
    After you import the Live type created clip into FCP, put it into the timeline and double click..check the ‘Filters’ tab in the source window…de click the shift fields tab…where that ‘shift fields’ filter comes from I don’t know but its there evrytime I create a movie with alpha channel in AE or LT…
    Hope that helps..
  • Kathy
    July 27, 2005 at 9:53 am
    that’s the one! Thank you.
    Kathy
