Activity Forums Apple Final Cut Pro Legacy Live Timecode Note Taking
  • Live Timecode Note Taking
    Posted by Kevin Hedin on October 2, 2006 at 8:47 am
    Sorry this is a bit off-topic, but I didn’t know where to post this one.
    I’m looking for a field note-taking solution that is Time-Code stamped, that allow you to type notes about an interview or a shot being recorded as it happens, thereby eliminating the post process of TC window dubs.
    Is there such a device that ‘SEES’ the camera TC, and stamps the info on a note your taking? Does this make sense?
    Mark Raudonis replied 19 years, 11 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    October 2, 2006 at 1:20 pm
    Does the camera have an external timecode output? If so, there are TC readers out there that should read it without a problem… Which camera is it?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Mark Raudonis
    October 4, 2006 at 4:58 am
    Kevin,
    Did you try to google this ? Hundreds of products came up.
    Here’s one.
    https://www.horita.com/time_code_logging.htm
    mark
