Activity › Forums › Adobe Premiere Pro › live stream saving to file
  • live stream saving to file
    Posted by Santosh Bhabal on June 15, 2012 at 1:12 pm
    Hi All,
    I am trying to save live stream to file.
    Below is the command which i m using:
    ffmpeg -i rtsp://IP_Address/stream_name -vcodec libx264 -s cif -vpre default -vpre baseline -g 60 -vb 150000 -acodec libfaac -ar 44100 -ab 128k -ac 1 -vbsf h264_mp4toannexb -f mpegts /tmp/file_name
    So, my question is what will be the output file extention i need to set. For e.g 3gp, mp4 etc.
    Regards
    Santosh
    Angelo Lorenzo replied 14 years, 3 months ago 2 Members · 1 Reply
  • Angelo Lorenzo
    June 17, 2012 at 7:13 am
    You should post this in the FFMPEG forum, this program has nothing to do with Premiere.
    With that being said, the -f switch is forcing the video to the mpegts container which is an MPEG2 transport stream. Your extension, for all intent and purpose, should be .ts or .m2ts
    It’s just a container, you can always remux as needed to MOV for instance.
    Angelo Lorenzo
    Fallen Empire – Digital Production Services
