Activity › Forums › Canon DSLR Cameras › Live output from Canon DSLR’s Via HDMI
  • Live output from Canon DSLR’s Via HDMI
    Posted by Stephen Rutledge on August 26, 2013 at 7:29 pm
    I know this might sound nubee, but i am wanting to take a live view out of any one of the Canon DSLR’s via the HDMI output, and run it into the BlackMagic Designs ATEM Production Switcher.. Can this work???
    A ” normal broadcast” camera will work, but i didn’t know if the DSLRs did as well
    Steve
    Kevin Duffey replied 13 years, 1 month ago 4 Members · 4 Replies
  • Jay Porter
    August 26, 2013 at 8:19 pm
    You can with the 5D Mk3. Not sure about the others.
  • Jay Porter
    August 26, 2013 at 11:21 pm
    You will need to run audio separately though.
  • Jonathan Ziegler
    August 27, 2013 at 3:37 pm
    Depends on which DSLR you have. The HDMI feed on most of the Canon DSLRs is an SD feed during recording (HD on playback for some reason). I don’t recommend it unless you are using the 5D MkIII or if you don’t mind the low-quality feed, any one will work.
    Save early. Save often.
    Jonathan Ziegler
    http://www.electrictiger.com
    520-360-8293
  • Kevin Duffey
    August 31, 2013 at 5:59 am
    Yes.. you can. The Canon t2i, 3ti, 4ti, and 5ti put out a 1080i60 signal, as I recently learned on my t3i. What you do is go into video mode, and do NOT record. The HDMI out live mode is 1080i/60. Using Magic Lantern you can clean up the output and get a 1620×1080 output (it’s actually 1920/1080 but there are black bars on the right and left).
    Not sure about 7D, 60D, 6D, etc..but I am guessing they also put out a 1080i/60 live mode signal. If you go into anything other than video mode, you’ll need to press the button that in camera mode starts recording. It would switch other modes into LCD mode (instead of view finder) and should also put out the 1080i/60.
