Live Frame Matching Two Shots on set – Something simpler than a switcher?
Hi Guys!
First post. Long time reader. Having some trouble with this one though.
This isn’t for a live event but the hardware can be seen as such.
My setup:
-2x Canon c-300’s with hd-sdi / hdmi out
-17″ panasonic monitor (hd-sdi in)
-whatever I need to achieve the following…I am building an interactive piece that requires some very detailed frame matching between two video clips . The shooting scenario is basically:
Shot 1 – 20 second *handheld* shot walking into a room, taking a semi-static position in room, and locking down as much as possible to line up for shot 2
Shot 2 – Camera is now on tripod – transition here needs to be seamless. Goal is to try and match the last frame of shot 1 as exact as possible to the first frame of shot 2. I understand there may need to be a little dissolve in post to keep it clean, but the idea is to frame match the hell out of this.
I need it close to exact. So my thought is to live onionskin / overlay the two frames on a single monitor to match this as closely as possible. To achieve this I’m thinking:
Capture shot 1 on camera A.
Pull that card, load it up on Camera B.
Setup shot 2 on Camera A, on tripod.
So I have playback of shot 1 on Camera B, and live view of shot 2 on Camera A – from there, both cameras run into a switcher / mixer where I crossfade between the two @ 50%, essentially onionskinning them to a live monitor.I feel like there may be a simpler way, but that’s the best I got. I need to move quick as there are a few of these happening throughout the day. So I’d like to avoid any card dumping and post-production scenarios.
Cheap is good though, and this doesn’t sound like the most affordable approach.
Any suggestions would be great.Best,
Marshall
