Activity › Forums › Adobe Premiere Pro › Live encoding for digitizing VHS
Posted by Doug Burnett on September 3, 2013 at 6:33 pmI haven’t digitized analog for years but I’m planning to finally start digitizing my old VHS tapes. I already have the hardware. I used to just use Adobe Premier to capture but realized I’m gonna have to manually encode and export each clip, which would take days with all the VHS tapes I have.
What tool can I use to just plain digitize my VHS straight to H264 with no other effort needed?
Jeff Pulera replied 12 years, 7 months ago 3 Members · 6 Replies -
Jeff Pulera
September 3, 2013 at 8:28 pmHi Doug,
The more info you can provide, the better quality of responses you’ll get. Mac or PC, and what “hardware” do you currently have for capturing from VHS?
There are low-cost (consumer) capture units that will go direct to H.264. I use the Matrox MXO2 Mini Max that can capture SD or HD direct to H.264 files using hardware encoding in the box. Even does hardware scaling – I’ll capture DV via S-video and convert to “H.264 Blu-ray” in a 1080i format.
Jeff Pulera
Safe Harbor Computers -
Doug Burnett
September 4, 2013 at 5:40 pmHi Jeff. Thanks for the response. I’m on a Mac 10.7 using a simple component-to-USB converter (https://goo.gl/zD0YRE). Was trying to do it cheap. Is there software that can convert live?
Jeff Pulera
September 4, 2013 at 6:00 pmHi Doug,
Cheap is right, looks like your capture device of choice is $8.86?!
Appears that it perhaps captures direct to MPEG-2 for writing to DVDs. But you want to capture straight to H.264? Not a Mac user, but even on the PC I don’t know what software would encode straight to H.264 from a cheapo input device, sorry
Jeff Pulera
Doug Burnett
September 6, 2013 at 4:35 pmYah, it was a dud 🙂 That’s what I get for being cheap. I did find this one which does go straight to H264, is made for Mac, and has good reviews.
https://www.elgato.com/video/video-captureThanks for the advice.
Eric Balboa
January 26, 2014 at 1:40 pmHi Jeff,
I’m capturing vhs via the Canopus advc 300 in the dv codec. Each 2-3 hour tape needs to go on it’s own blue ray disc. Would you recommend transcoding to Mpeg2 blu ray or h264 blu ray in 1080i?
I’ve done a couple with the Mpeg2 setting at “high quality” and the file size is rather small as the default bitrate is only at about 5.
Should I stick with Mpeg2 and manually bump the bitrate up to 10 or even 15, or should I just use h264 1080i?
Thanks for your help.
Jeff Pulera
January 27, 2014 at 2:43 pmHi Eric,
Though I’ve never actually done it, you’re supposed to be able to put DVD material on a Blu-ray disc. I would not bother with upconverting the material to 1080i first – the Blu-ray player will do the upconvert for you upon playback using quality hardware methods, and this should work better than doing it in software.
Just encode for “MPEG-2 DVD” with a CBR 8.0 bitrate setting.
Hope this works out for, I’ve not tested it but have seen many forum posts about putting DVD files on Blu-ray.
Jeff Pulera
