Live Capture Options
The situation is this; the company I work for currently provides live coverage and replays of greyhound racing that gets screened around the CCTV of the stadium. We currently run an analogue feed from the betacam into a DVCam deck (PAL), record the race, stop, rewind and run replays from that. This also allows us to run off DVDs of the races which people can buy on the night. This all works well and is cheap and cheerful.
However, we want to be able to achieve at least the same, preferably better efficiency by utilising a tapeless workflow. This is one way we could do it: feed an analogue signal into a Kona LHe (which we already have), and ‘Capture Now’ through FCP/Non Controllable Device to transcode to DV PAL. This would also require a reasonably fast RAID (which we also already have).
What I’d like to know is whether there is a simpler/more effective solution to this. Any software other than an NLE that will do it? What about firewire capture? Would we run the risk of dropping frames?
Many thanks in advance,
Alex
