Activity Forums Apple Final Cut Pro Legacy Live Capture, Non Control, with Time Code
  • Live Capture, Non Control, with Time Code
    Posted by Tucker Quenette on September 19, 2010 at 9:01 pm
    Hello,
    Trying to get FCP6 on my laptop to capture off a deck as a non-controllable device AND maintain the timecode on the deck.
    I did a quick search here, and it isn’t looking too promising, hoping someone might have a solution as I am in a time crunch.
    Thanks in advance,
    T
    Bouke Vahl replied 15 years, 12 months ago 5 Members · 11 Replies
  • 11 Replies
  • Chad Tingle
    September 19, 2010 at 9:28 pm
    [Tucker Quenette] “Trying to get FCP6 on my laptop to capture off a deck as a non-controllable device AND maintain the timecode on the deck.”
    That’s not possible.. you cannot acquire time code without some kind of machine control i.e firewire, rs422 or rs232. The machine control is what transfers the time code track from your tape to FCP.
    Chad Tingle
    Producer/Editor
  • Tucker Quenette
    September 19, 2010 at 9:38 pm
    Thanks for the response, Chad.
    Someone in our crew came up with the option to replace a windows laptop with Premiere about an hour ago and we are scrambling to see if we can make a MBP with FCP usable as it would save us a few hours in our preparation time for post.
    I guess we will have to keep on researching and try again if an option becomes available.
    T
  • Michael Sacci
    September 20, 2010 at 5:30 am
    how are you connecting the deck to the laptop?
  • Bouke Vahl
    September 20, 2010 at 8:02 am
    If you have timecode somewhere in the neighbourhood, you can use a black box to convert LTC to 422, and have FCP look at that.
    Besides black boxes, my latest version of LTC reader outputs 422 as well. You can run it on any computer you like, and it could run in the background of the FCP machine capturing.
    Contact me direct if you want to toy with it,
    bouke at videotoolshed dot com
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
  • Tucker Quenette
    September 20, 2010 at 11:08 pm
    we connect through firewire 6pin to 6pin. side note, premiere was able to connect as a noncontrollable and maintain timecode
  • Bouke Vahl
    September 21, 2010 at 8:33 am
    If you connect over firewire, why not just do a ‘capture now’?
    Bouke
  • Rafael Amador
    September 21, 2010 at 9:09 am
    In FW, the TC goes on the stream.
    Rafael
    http://www.nagavideo.com
  • Tucker Quenette
    September 21, 2010 at 3:30 pm
    as a controllable device, capture now basically “hits stop on the deck” and fcp gives you an error message. as a non controllable device, the location where the decks timecode should be has disappeared and when you hit “capture now” you get footage that does not contain the deck’s timecode.
    very unusual problem for me to not have a function in fcp that is a function available in premiere
  • Rafael Amador
    September 21, 2010 at 4:03 pm
    So set “Non controllable device” in the capture settings.
    rafael
  • Tucker Quenette
    September 21, 2010 at 7:01 pm
    setting to “non controllable device” removes the timecode coming off the deck – this is the problem i am trying to remedy – i want to set as “non controllable device” AND maintain timecode, as i am able to in premiere
    thanks,
    t
