Activity Forums VEGAS Pro Live capture help in HDV!
  • Live capture help in HDV!
    Posted by Cbolton on September 11, 2005 at 7:32 pm
    Hi there
    I am atempting to do a Live stream capture diectly from the Sony HVR-Z1U camcorder into Sony Vegas. (In other words no tape.)
    I can capture the footage from tape no problem in HDV and DV, and I can also live stream (no tape) video via DV as well.
    Does any one have a solution in Sony Vegas, or any other PC based system that can do this??
    Thanks for the help…
    Chris
    Mark Postma replied 21 years ago 4 Members · 6 Replies
  • Peter Wright
    September 12, 2005 at 12:35 am
    I haven’t had the need on a job yet, but I did a trial a while back and was able to record from Z1 straight to external HD with my old laptop, no problems.
    This was using the internal Vegas capture.
    Peter Wright
    Perth, Western Oz
    http://www.allroundvision.com.au
  • Cbolton
    September 12, 2005 at 5:14 am
    Hi Peter Wright
    Thanks for the repley to my issue.
    I just wanted to clarify that you where capturing live from the camera and not capturing from a tape??
    Was there any special settings that I have missed?
    Thanks again!
    Chris
  • Mark Postma
    September 12, 2005 at 8:29 pm
    It should be pretty straight forward – just capture with the camcorder plugged into the firewire. However, you will NOT be able to do HDV, only standard def capture.
  • Jerry Waters
    September 12, 2005 at 10:06 pm
    You can capture HDV directly to a hard drive without running the tape in HDV Rack. You can download a trial at Serious Magic.
  • Peter Wright
    September 13, 2005 at 3:38 am
    Vegas 6 internal capture will capture HDV straight from the Lens. You won’t get any preview on computer screen, or changing time code numbers as evidence of capture, but it works.
    Try it.
    Peter Wright
    Perth, Western Oz
  • Mark Postma
    September 15, 2005 at 1:34 pm
    Sorry…should have clarified…HDV is capturable (compressed MPEG2), but HD (uncompressed) is not capturable through the firewire.
