Activity › Forums › Apple Final Cut Pro Legacy › Little Canon camera to capture from…
  • David Heidelberger
    November 7, 2007 at 8:49 pm
    Are you talking about just Mini-DV stuff? Or the HD as well?
    For SD Mini-DV firewire, I wouldn’t recommend using a Canon camera. Don’t know if it’s a universal problem with Canons, but the three that I’ve captured with in the past (XL-1, XL-2, and a ZR-60, I believe) hog your firewire bus so that you can’t capture to a firewire drive unless you buy a firewire PCI card to get a second bus. I believe that other brands won’t give you this problem.
    If you’re talking about HD from the H1, I’m not going to be able to help you.
    – David
  • Ron James
    November 8, 2007 at 12:33 am
    HV20 would do it. I’ve been using it AND capturing to a firewire drive. No problems.
