Activity › Forums › Apple Final Cut Pro › Little App-for ‘Pre-Flights’ when using Libraries
  • Little App-for ‘Pre-Flights’ when using Libraries
    Posted by Andreas Kiel on May 9, 2019 at 6:07 pm
    A common thing:
    When opening “foreign” or longer unused libraries the problem arises that fonts or templates may be not found.
    For missing fonts this font/font face will be replaced by the “default font” of the template and some parameters will be reset. The problem may arise that FCP might save this change – which is very annoying.
    Unfortunately (for personal reasons) I can not update my old X-FX for Mojave as fast as I would love to do, I have decided to bring a part of it into a small stand-alone app: X-Library Check
    This mini-app searches a library (.fcpbundle) for all fonts and external motion templates, lists them and warns if something is missing.
    Application usage: Use Menu / Button to open a Library or drag Library to the App’s Icon and wait a bit.
    The result/report is saved as “Library Name” & “-check.txt” on the Finder level of the library.
    This first version is free and it is available here:
    https://www.spherico.com/filmtools/X-Files/X-Library-Check/XLC-Install.dmg
    Spherico
    \”He who fights with monsters should be careful lest he thereby
    become a monster. And if thou gaze long into an abyss, the abyss will
    also gaze into thee.\” – Friedrich Nietzsche, Beyond Good and Evil
    Michiel De leeuw van weenen replied 7 years, 4 months ago 2 Members · 1 Reply
  • Michiel De leeuw van weenen
    May 22, 2019 at 6:22 pm
    That’s a great ‘very big’ little tool Andreas. Thank you for creating and sharing.
