Activity › Forums › Lighting Design › Litepanels
  • Litepanels
    Posted by Michael Capehart on January 18, 2006 at 11:43 pm
    Does anyone have knowledge on how to build a LED light like the LITEPANEL? I am curious to know if there is a cheaper alternative to their costly kits.
    Chaz34 replied 20 years, 7 months ago 5 Members · 4 Replies
  • Frank Otto
    January 19, 2006 at 5:32 pm
    Y’know…it’s not so much the knowledge as it is the tools and the certification. The products we use aren’t exactly difficult to create – but building one…that’s different.
    List of item you’ll need are:
    * Supply of LEDs in the proper color temp and amount for your application
    * Power supply and circuit to drive the LED
    * AC cable not exceeding 12′ in length and typed to match load
    * PC board of a design to adequately mount the LEDs
    * Case, constructed of metal or thermoplactic
    * Yoke or other mounting device (third party supplied or design and mill yourself)
    * Misc. hardware (screws, bolt nut washer, grommets, etc.)
    TOOLS:
    * Drill press and jigs
    * Metal saw
    * Metal bending tool(unless you buy case from a third party)
    * Soldering tool and heat sink – LED can be dammaged by heat like any diode
    * Buffer and grinding wheel for deburring and polishing
    IF YOU USE PLASTIC:
    * Thermoplastic peg table or vaccumn table
    * Forming tools
    Note the Drill press, bits, saws, buffer and grinding wheel can be used as well – but you’ll need specific wheels, bits and blades for plastic.
    Once you have created your design, it’s time to prototype. If you are using this for just yourself, then your prototype becomes the end product or possibly first of several you’ll build for your use.
    You’ll also want to register your plans with the Patent Office…just in case you’ve, A) infringed on someone, and, B) might have designed something unique – you may not want to manufacture it, but you don’t want someone else profiting off your hard work eiather.
    Last is getting certification. If you use the device at home you have very limited liability – if you use it for hire there will be insurance issues – most insurance riders will demand UL, CSA type acceptance, many will accept Calif. Fire approval. If your “homemade” device lights up a fire you will automatically be liable – regardless of how professional the construction was.
    This isn’t to discourage you from building your own devices – I’ve built many in my shop. But I did spend time at Century-Strand as an assembler and machinist (thought it would be a stepping stone into lighting design – it wasn’t) and know the complexity of the build process and the legalities.
    Bottom line – unless you are developing something for retail, the cost of one-offing is far more (labor, supplies-parts, etc) than the cost of purchasing.
    Cheers,
    Frank Otto
  • Mitch Gross
    January 19, 2006 at 6:35 pm
    Actually, I think they’re pretty cheap for what they offer. And I think there is some sort of rebate promotion going on right now. They’ll probably be introducing a new model at NAB.
    Mitch
  • Tom Maloney
    January 22, 2006 at 1:35 pm
    Or if you are in a hurry remember this simple saying:
    West VirginiA …… or watts divided by volts = Amps
    keep it at 100 volts and you always will be safe
    for example:
    1000 watt lamp divided by 100 volts = 10 amps
    In the real world the voltage would be 110 in a house so the amps would be 9.09, safe for a 15 amp breaker
    but you can see you could not plug two 1ooo watt lamps into a 15 amp circut
    good luck
    Tom
  • Chaz34
    February 7, 2006 at 2:39 am
    Michael,
    I invite you to surf on over to our site, http://www.zylight.com and take a look at what we have to offer. Its an alternative you might be interested in.
    –Chaz
