Activity › Forums › Adobe After Effects › Liquify/Drops rain transition/effetc
Posted by Blue.eagle on June 19, 2005 at 6:09 amHi all,
I’m editing a videoclip and would create a sort of effect/transition as a drops rain that comes from top to bottom and wipe out the video sequence placeed on top layer. Any idea?
Thanks in advanceRyan replied 21 years, 3 months ago 2 Members · 5 Replies -
Blue.eagle
June 19, 2005 at 4:22 pmIt would be possibile create this kind of transition by displacement map ?
sigh…anyone can suggest me a solution? -
Ryan
June 19, 2005 at 10:10 pmLots of questions need to be answered for this technique.
A: Are you wanting the rain to go from the top of the screen to the bottom?
B: How big are the drops you are using for the transition?
C: Do you want it so that rain hits the screen from an angle and the video smears down the screen and washes away? (that actually sounds like a really good concept)
Answers to these questions could reveal a solution, and if not, post your answers and I will give suggestions based on them.
Ryan
Blue.eagle
June 20, 2005 at 6:52 amThanks for your attention Rayan
a) yes
b) many drops…so they would be small
c) yes -
Ryan
June 21, 2005 at 3:42 amUse the Silouhette luma blending mode on a layer that goes from black to white. Use a brush that acheives the effect you want and animate over time.
Also use the liquify tool to achieve the smear effect of the footage.
A: Liquify in streaks on your footage.
B: Animate brush strokes on Silouhette layer to coinside with the liquify strokes.
C: Repeat as many times as necessary to remove video layer completely.
D: As for creating the rain, search the cow for many examples on how to do this.
Hope this helps
