Activity › Forums › Adobe After Effects › Liquid motion
  • Max Baxter
    June 12, 2014 at 7:45 pm
    No I didn’t, my apologies if it came across like that. That technique is EXACTLY what I want. You are a life saver, Thanks very much
  • Brian Charles
    June 12, 2014 at 8:06 pm
    Here’s the project file if that helps.
    7616_circletosquare.aep.zip
  • Max Baxter
    June 12, 2014 at 10:19 pm
    that’s brilliant. Now how would I change it from being a stop watch to being a person. I thought if we did Circle to Square it’d work fine but the way you did it wouldn’t work changing between two files. Any thoughts?
  • Brian Charles
    June 13, 2014 at 1:05 am
    [Max Baxter] “that’s brilliant. Now how would I change it from being a stop watch to being a person. I thought if we did Circle to Square it’d work fine but the way you did it wouldn’t work changing between two files. Any thoughts?”
    If the morph from one object to another happens in the nested composition, the rest is easy. Here is an example:
    7617_circletomancs5.5.aep.zip
  • Max Baxter
    June 13, 2014 at 4:24 pm
    that’s great. I’m trying to figure out how you got it to transform to being the man but I have no idea, please could you expand how you did this please?
  • Brian Charles
    June 13, 2014 at 5:09 pm
    [Max Baxter] “I’m trying to figure out how you got it to transform to being the man but I have no idea, please could you expand how you did this please?”
    Its a mask path on a solid layer. The mask path is keyframed.
  • Brian Charles
    June 13, 2014 at 6:42 pm
    Here’s a technique using still images:
    Image Morph with Flo Motion
  • Jp Pelc
    March 1, 2024 at 3:37 pm
    Stephen I had to login just to tell you that this comment you left nearly 10 years ago has been a lifesaver. I use this technique all the time! You are a true champion in this world of motion graphics
Page 2 of 2
