Activity Forums Maxon Cinema 4D liquid metal
  • liquid metal
    Posted by Antony Buonomo on February 12, 2007 at 9:12 pm
    I mostly use AE and PS but recently I have started toying with C4D. Today, as an experiment, I set myself the task of learning to make some ‘liquid metal’. As a starting point I have found a tutorial that uses Path Deformer Lite. It’s nice but I would like a bit more control of the flow, blobbiness, stickiness etc as well as learning how to make it interact with a surface (is this possible?)
    If someone could point me to a tutorial I would be very grateful.
    A
    Mylenium replied 19 years, 7 months ago 2 Members · 1 Reply
  • Mylenium
    February 13, 2007 at 6:39 am
    [Antony Buonomo] “It’s nice but I would like a bit more control of the flow, blobbiness, stickiness etc as well as learning how to make it interact with a surface (is this possible?)”
    You need Thinking Particles for that. Once you have your particle setup, simply put it inside a Metaball object. This also works with the normal particle system, but the level of control is limited.
    Mylenium
    [Pour Myl
