Activity Forums Adobe After Effects Liquid Metal Person
  • Liquid Metal Person
    Posted by Joey Kadin on May 15, 2008 at 4:02 am
    Is it possible to do this effect in AE without any other 3D software?
    I want to do a very quick (couple seconds) effect of a person who turns into liquid metal, then melts into a puddle. Examples: Capri Sun Commercials, Terminator, Alex Mack. I’m thinking there may be a way to do it with just AE because I don’t need to animate a liquid metal person, just have a sitting person turn into liquid metal and melt.
    Any ideas?
    Thanks in advance.
    Joey Kadin replied 18 years, 4 months ago 4 Members · 6 Replies
  • Brendan Coots
    May 15, 2008 at 5:23 am
    That is pretty much always done with a 3D package like Maya. You probably could cobble together a similar effect just using After Effects, but it will fall far short of the examples you cited.
    Brendan Coots
    Splitvision Digital
    http://www.splitvisiondigital.com
  • Matthew Krumins
    May 15, 2008 at 6:40 am
    I have no idea how and i’ve never done this but you could try and stack a few effects on top of each other. For instance, use Trapcode Particular to “melt” your greenscreened/masked man into a pile of particles on the floor and then apply a blobbize effect over the top. It won’t be perfect but for a very quick shot you might be able to get away with it. if you don’t have trapcode particluar you could try to use CC_Balls or somthing?
  • Roger Burton
    May 15, 2008 at 10:35 am
    Hi – I came across this a few days ago – bloody clever and, of course, for photoshop. I haven’t looked at it properly but you may find it of some use:
    https://www.graphics.com/modules.php?name=Forums&file=viewtopic&t=5732
    Roger
  • Joey Kadin
    May 15, 2008 at 4:04 pm
    That’s what I figured. I’m taking a Maya class in the fall (which means I’ll have a system with Maya on it to play with), but I still would like to try a simple version solely in After Effects. Thanks.
  • Joey Kadin
    May 15, 2008 at 4:06 pm
    I have Trapcode; that’s kinda what I was thinking of trying, thanks. Either that, or maybe trying to build a person-shaped blob out of particles and animate a mask to change from the real person to the particle blob underneath. Thanks.
  • Joey Kadin
    May 15, 2008 at 4:07 pm
    That’s pretty neat. I’ve used some Eyecandy stuff in photoshop to do chrome before, but I never thought of doing it with just different curves and layers. Thanks. Maybe this combined with some other stuff might work out.
