Activity Forums Maxon Cinema 4D Liquid in C4D
  • Liquid in C4D
    Posted by Sala Sultan on September 16, 2010 at 3:54 pm
    Greetings!!
    How come I couldn’t find a tutorial or information how to make liquid in C4D? Just liquid like coffee in a mug or water falling into a cup..
    And also there’s no tutorials about cracks in grounds or walls… Like for examples ground and walls crack while earthquick strike
    I hope I made sence
    Thanks a lot and hope someone will put couple of tutorials out there to teach the rest of us
    Thanks!!
    Sala
    Tomas Burki replied 14 years, 2 months ago 4 Members · 5 Replies
  • Adam Trachtenberg
    September 16, 2010 at 5:09 pm
    Cinema doesn’t have liquid simulation built in, although there’s at least one plugin developer working on it. There’s also RealFlow, an external application that interfaces with Cinema via a plugin.
    For pouring water, about the best you can do now is to use particles with metaballs, but it tends to look more like jelly than liquid.
  • Sala Sultan
    September 16, 2010 at 11:39 pm
    Thanks for the quick response!
    Actually I kind of used particles and as you said it didn’t look right… There for I was wondering how all those guys on the net did the water simulation in C4D, so it turned out I have to have a 3rd party plugin
    Do you know how to make a crack in a wall or ground? Let’s say there’s an earthquake or someone punched a wall and made a crack, it doesn’t just a pear, the crack runs from one erea to another wiggling left and right like a snake or like a growing plant movement, I really hope you got what I’m saying, cause it’s even dificult for me to understand d what I’m saying
    Tha ms alot and hope to hear from you soon
    Sala
  • Kim Segel
    September 21, 2010 at 7:11 am
    I haven’t been able to do realistic cracks solely inside C4D but one thing you might try is this:
    Assuming you don’t need real deep cracks in your geometry, you could get away with texture and bump mapping ‘real’ cracks into your surface.
    Take or find a photo of real cracks. Then, in an appropriate program (like AE) wipe the cracks in from the center and save this animation.
    Use this file as a texture and as a bump map and you will get nice spreading cracks.
    Good luck…
    Kim
    A computer once beat me at chess, but it was no match for me at kick boxing. –Emo Philips
  • Sala Sultan
    September 21, 2010 at 3:30 pm
    Thanks Kim!
    Is it better just to do the whole thing in AE or working with C4D would make it more realistic?
    Which rout would you take?
    Sal
    Sala
  • Tomas Burki
    July 6, 2012 at 3:39 pm
    The only real thing that remotely looks semi-realistic in C4D would be to use a regular object (like a sphere or landscape making it spherical) then using the “melt” deformer. Review the link below to see a preview.
    4379_screenshot20120705at11.18.34am.png.zip
