Activity Forums Adobe After Effects liquid effect in a text
  • liquid effect in a text
    Posted by Jose Arce on August 8, 2011 at 2:33 pm
    Hi I just want to learn how to create this effect in after, in this video in the min 00:36 and 00:43 https://vimeo.com/18678091
    the transition of the letter, is an expression on it or is with mask and keyframes.
    Thanks.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Jose Arce replied 15 years ago 2 Members · 2 Replies
  • Tudor “ted” jelescu
    August 8, 2011 at 9:00 pm
    You can create that liquid distortion by either using a Mesh Warp or a Displacement Map. I would use the Mesh Warp as it gives you more control over the distortion.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Jose Arce
    August 9, 2011 at 12:31 am
    I going to try…Thanks
