  • Posted by Chemic34 on October 27, 2005 at 7:10 am
    I’m doing some animation in after effects, in which I need to do some lip syncing. I was wondering, what would be the easiest way to achieve this? Should I animate just the mouths in flash, then import the .swf’s into after effects? After effects seems to be pretty crappy with audio, atleast from my experiences using it. I’m really not sure what to do and I don’t have much time to experiment because the project is due soon. So what do you guys thing would be a good solution? Thank you very much.
    Aharon Rabinowitz replied 20 years, 6 months ago 4 Members · 3 Replies
  • Roland R. kahlenberg
    October 27, 2005 at 4:34 pm
    Audio works fine for me in AE. If experimentation is out of the Q, then the good ole’ eyeball should do the trick. If you’re comfortable with masks, then I suggest you animated the mouths in AE. You can re-name the masks according to the type of sounds that you make, then copy and paste those sounds that are repeated as and when required.
    HTH
    Roland Kahlenberg
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files
  • Guy
    October 27, 2005 at 4:58 pm
    if it is just quick and rough lip sync, you can create 2 positions, open, and closed. (lets say using reshape or liquify)
    Then you can convert audio to keyframes and link an expression from your reshape or liquify effect percentage to the audio amplitude keyframes.
    for more control look into creating a few different mouth positions (for different sounds)
    and maybe use Trapcode sound keys to drive the keyframes.
  • Aharon Rabinowitz
    October 28, 2005 at 1:47 pm
    We covered this here:
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?univpostid=857968&forumid=2&postid=857974&pview=t
    My files are still available for download.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
