Activity Forums Adobe After Effects Expressions Lip Sync with an expression twist
  • Lip Sync with an expression twist
    Posted by Lou Borella on September 24, 2010 at 3:49 pm
    I know there are a ton of tuts out there on syncing different lip layers to audio.
    I just watch Aharon’s “Mr Face” tut
    https://library.creativecow.net/articles/rabinowitz_aharon/lip_synch.php
    and Andrew Kramer’s “Audio to Animations” tut.
    https://www.videocopilot.net/tutorial/audio_to_animation/
    I’m hoping that someone can help me combine the two with the proper expression.
    Here is the rub. I only have 2 different graphics for the mouth layer. I don’t have the time to scrub thru the audio to manually add keyframes so the mouth opens and closes. Im hoping that I can take Andrew’s idea of converting the audio to keyframes and using those keyframes to trigger the mouth to open/close in the time-remapped layer that has the mouth gfx. I’m sure there is an expression that will allow me to trigger frame 1 or 2 depending on the amount of audio.
    Thanks in advance
    Lou Borella
    Aza Allen replied 15 years, 11 months ago 2 Members · 1 Reply
