Activity › Forums › Adobe Encore DVD › Lip sync problem
  • Lip sync problem
    Posted by Calvin Dean on April 25, 2006 at 12:35 am
    My DVD contains 5 different videos. One video has a lip sync problem (audio slightly ahead of video). But it happens only on one of my DVD set-top players, an older model. All 5 video play fine on two other newer set-top players. The problem is strange because I’ve used the same settings numerous times and never had a problem.
    I’m using 8x Taiyo Yuden media. Encoding is 7.2Mb/s VBR maximum (7.0307 video. The remainder is Dolby audio.) My burner is 3 years old, a Plexor 708A. The disk was burned at 1x. I’m using Encore 1.5.
    I’ve also tried burning at 4x…same results.
    Calvin Dean replied 20 years, 5 months ago 2 Members · 3 Replies
  • Calvin Dean
    April 25, 2006 at 1:09 am
    btw, I’m using the latest firmware.
  • Tim Kurkoski
    April 25, 2006 at 5:44 pm
    If the problem only exists on one player, try different media and/or a different bitrate for the video. Some players just don’t… er, play well with all discs and data.
  • Calvin Dean
    April 25, 2006 at 9:04 pm
    I’ve tried Maxell DVD+R and Taiyo Yuden DVD-R. No difference. I even tried re-exporting the video and re-encoding. No change. Since one video out of 5 is performing strangely on only one of my three set-top players, I’m chalking it up to the deck…a 5 year old RCA dual DVD/VCR oddity. I use this player as my lowest common denominator. If it’ll play here, it’ll play anywhere. Okay so, this one’s wierd. Hopefully the client doesn’t have a 5 year old RCA dual DVD/VCR player. My other two players are newer Sony models. My disk is rock solid on Sony.
