Activity Forums Adobe After Effects Lip-sync
  • Posted by Gary Jarvis on December 13, 2011 at 12:42 pm
    I am having a bit of a problem with lip-syncing, what’s happening is that after I finished each of 63 syncs (all my characters sing a chorus) they work great until, I de-compose/pre-compose them a couple of times to make additions and/or position changes. (layer de-compose)
    My procedure is:
    Three layers psd file of a top lip, bottom lip and a behind lips color.
    Import into AE as a composition.
    Import audio then, R click – keyframe asst – convert audio to keyframes – this creates a null – open null – effects – both speakers.
    Then I go back to my lips file top lip – puppet tool – 4 pins – one in each bottom corner of lip and one either side of top off center. I then pick whip from off center left pin to slider in audio and add an expression, amp = +.4;
    temp = thisComp.layer(“Audio Amplitude”).effect(“Both Channels”)(“Slider”);
    value + [0,temp*amp]
    I then do the same to the other off center pin (not side pins, they are to hold lip in position.
    I then do the same to the bottom lip only, I change the +.4 to a -.4.
    the next step was to pre-compose them and duplicate multiple times. After a few de-compose’s I got this
    and lost my lip syncs.
    What an I doing wrong?? tks
    Gary Jarvis replied 14 years, 8 months ago 1 Member · 5 Replies
  • Gary Jarvis
    December 13, 2011 at 6:02 pm
    Yep Dave u hit it on the button tks mate
  • Gary Jarvis
    December 13, 2011 at 8:53 pm
    I have an acapella version and a music accompanied version, the acapella version gives a better lip-sync so, would I still get a good sync if I whipped into the acapella, then turn down the acapella sound and background the animation with the music accompanied song?
  • Gary Jarvis
    December 13, 2011 at 11:33 pm
    Thanks for your response Dave,
    Being new at animation, as a matter of fact, AE is my first step, that being the case, I am editing and rendering in AE. My thinking for lack of experience is, if I can’t kill the volume of the acapella w/o interfering with the lip-sync, then I would render the acapella version and then bring it back into AE turn down the acapella sound and add the musical version.
    This is not meant to be a pro job, it will be played on a 65″ plasma with a bunch of mates. My main concern is the animation and am more than open to direction
    Tks Gary
  • Gary Jarvis
    December 14, 2011 at 12:38 am
    If I understand your question correctly Dave, and you asking what I will render it to,it will probably something real simplistic like QT
  • Gary Jarvis
    December 14, 2011 at 1:47 am
    Hey Dave it seems to be working, I created the audio keyframes, applied my top lip then bottom lip sync using puppet tool and just duping and moving into position, it really looks like a great sync to the words of the song.
    Tks for your help Gary
