Activity › Forums › Creative Community Conversations › ‘Lion’ Apple Mac OS X 10.7: Sneak Preview
  • Erik Lindahl
    July 4, 2011 at 1:45 pm
    The ancient OS-X-native Internet Explorer 5.5 will no longer run, either
    Oh no! 🙂
    The only really issue I find with Lion is the download > install scheme. They should offer a download > disc image scheme I’d say. Other than that I understand they want to cut off all the old code. Most people that require things like Rosetta will most likely survive staying in MacOSX 10.6.
    Erik Lindahl
    Freecloud Post Production Services
    http://www.freecloud.se
  • Chris Kenny
    July 4, 2011 at 1:49 pm
    [Erik Lindahl] “They should offer a download > disc image scheme I’d say.”
    There’s an image file hidden in the installer package. It can be restored onto a drive (or, I suppose, burned to an actual disc) at which point you have a bootable installer like you’d have had for any other version of OS X.
    Digital Workflow/Colorist, Nice Dissolve.
    You should follow me on Twitter here. Or read our blog.
  • John Pale
    July 4, 2011 at 3:03 pm
    I have read the installer actually creates a mini emergency boot partition on your drive, from which you can reinstall the OS, if necessary. You can create a disc image of this partition on a DVD or USB drive, too. No copy protection.
  • Everest Mokaeff
    July 4, 2011 at 5:44 pm
    Personally, I find it very satisfying not to have installation disk every time. I test the system since their developer release ver 3. As to FCS3 including third party components everything works fine. Though I would refrain to recommend use it in production yet. It’s too early. BTW, yes indeed you have clean install version you can restore from. (If anybody could tell me how to turn off automatic proofreading in Safari 5.1 on mac os 10.7 I’d appreciate it. )
    Sony PMW-EX3, Canon Mark II 5D, FCS3 in Moscow
    http://www.mokaeff.com
  • Erik Lindahl
    July 5, 2011 at 8:55 am
    I thought Lion would require the system to have 10.6.8 installed, or is that old intel? If not, this system is fine / great.
    Erik Lindahl
  • Everest Mokaeff
    July 5, 2011 at 1:09 pm
    Yes it’s being installed from within 10.6.8. I didn’t try “clean” installation from bootable disk/partition. I guess it’s pretty easy – just make a proper copy of your Lion as you did with any other previous version of mac os.
