Activity Forums DaVinci Resolve Lion and Davinci
  • Lion and Davinci
    Posted by David Didato on August 19, 2011 at 3:57 am
    Anyone succeeding in rendering on a Lion system?
    I’ve been getting frame rate dropping to 0fp followed by “Error occured communicating w/ Digital Powerhouse Decoder”, then sometimes getting:
    “Unable to communcate with the D. P. Please restart Resolve.”
    Or, just flat out kernel panics while rendering RED footage to ProRes HQ or LT. Specs are:
    I’ve tried everything from 1/16 res to 1/4 res good. Can’t complete a render of a short timeline with 8 red clips, less than 20 minutes.
    New MacPro 5,1: Quad Core 2.8Ghz – came with Lion installed
    Also tried OS 10.7.1 (upgraded yesterday)
    Nvidia GTX 285 GPU
    Nvidia GT 120 GUI
    BMD Decklink SDI
    24 Gb RAM
    eSata raid 0 array
    Nvidia CUDA driver 4.0.16 or 4.0.50 (tried both)
    Davinci 8.0.1
    Or if anyone has a similar system with Snow Leopard working, let me know. I’m planning to try another boot drive with 10.6.
    David D
    Cris Baltazar replied 15 years, 1 month ago 4 Members · 4 Replies
  • Sascha Haber
    August 19, 2011 at 6:41 am
    I am running 8.0.1 on 10.7.1 with a 470GTX and just finished a documentary…rendering SD only , but with 150 fps.
    I ve seen those messages only when working on old projects I imported from 7.1
    Your setup sounds good, could you publish the project ?
    I will just replace your Red clips with some I have and see if the same errors come up , if you like.
    A slice of color…
    DaVinci 8.0.1 OSX 10.7
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB eSata 6TB
    GTX 470 / GT 120
    Extreme 3D+ WAVE
    http://www.saschahaber.com
  • Kevin Cannon
    August 19, 2011 at 5:51 pm
    I have a more similar set-up than Sacha perhaps, Resolve 8.0.1 Lion 10.7.1 with a GTX285, GT120, and this week I’ve been working with mostly 2:1 4K and 4.5K RED footage. I’ve had a few problems with the upgrade to Lion; in the end I stepped back to CUDA driver 4.0.17 (.19 wasn’t being found by resolve).
    I’ve had a couple of those errors – rendering to ProRes4444 I had the frame rate drop to zero and I got an error along the lines of “timeout occurred on frame 4” and I’ve also seen the “Error occured communicating w/ Digital Powerhouse Decoder” but that one I got occasionally on 10.6. But I didn’t get those errors as often as you (maybe once on 7 short renders, and none on a big DPX render today).
    It could be unrelated, but I changed a lot of the power saving settings in Lion (it’s pretty aggressive in sleeping hard disks and such) and I saw improvements in Resolve’s responsiveness…
    KC
    prehistoricdigital.com
    hardworkingpixels.com
  • Sascha Haber
    August 20, 2011 at 6:31 am
    I removed the AppleDisplayPowerManagement.kext completely.
    Also i am on CUDA 4.0.50 now…
    17 was giving me nothing but lemons, and I prefer beer over lemonade 🙂
    A slice of color…
    RAID0 8TB eSata 6TB
    GTX 470 / GT 120
    Extreme 3D+ WAVE
  • Cris Baltazar
    August 22, 2011 at 12:50 pm
    Anyone with a Dual Quadro 4000 with MacOSx 10.6.8 and the latest CUDA 4.0.50?
